1 - 13 of 13 Posts
yes, i need the ignition barrel, and the yellow code box is there with the lock set
so if i bought this and fitted it then it should work??
thanks.
i lost my only key, i dont have any other keys or key card code
i was just planning on getting a second hand set that will plug and play
thanks for reply's
When I replaced my CODE box years ago (due to failure) I had to change the ECU as well, as they were paired (locked) to one another.
Admittedly this was back in 2008 and things have probably moved on.....
Can somebody confirm?
thanks for reply's
It would be cheaper to get another key made than trying to get a used ecu set for that year 3ltr
Give us a call:)
Discussion Starter · #11 ·
thanks guys, i found the keys for it along with some other spare keys for another car ive got after cleaning out my kids room :D
May I suggest that you get a clone copy of your only key? :)
And untill that is done, take a good picture of the key. That will make it easier to make a new one if you loose it again.
1 - 13 of 13 Posts
