1 - 2 of 2 Posts
Hi
I recently installed a new air con control unit and my odometer is flashing. A proxy alignment is needed, but I cannot connect to the can bus.
I am using multiecuscan V3.3, my car is a 2004 GT 1.9JTDM. I have tried using a bluetooth ELM 1.4 device, also tried a ELM1.2 bluetooth device and also a ELM 1.3 USB device. Have also tried with ignition on/off etc.
The error I get is empty proxy file in body computer.
Any help would be great? This is really bugging me
I've found ELM adaptors flaky, mostly working but not working at all on some things. EG can read injector codes but can't write them on both the USB and Bt ones I own. KKL EOBD has none of these problems here, though you need a switchable cable or adaptors for body computer connection.
edit: ignition has to be on. If you get the same result in MES with ignition off, I would take that as a clue to ELM issues.
1 - 2 of 2 Posts
