21 - 23 of 23 Posts
Discussion Starter · #21 · (Edited)
Today I decided to check operation manual and electrical schemes. Inside 5560 Instruments manual (see attach) I found text on page 13
Display after the 6 services.
Once all 6 services are over no message is displayed automatically and the relevant item can no longer be selected from the set up menu (it is no longer activated).
Reset
At each service interval, the Service personnel should:
  • reset the km (or miles) counter to the starting value using the diagnosis equipment;
  • record that the Service has been carried out; a record of the last service carried out should remain with details of: service date/ service no. carried out / total mileage.
This information is preserved in the memory even if the vehicle battery is disconnected.
Does any have opinion what it means? Is information only about service item?
The car is to be serviced every 30,000 km. You can check how far you are from the next service by going through the menu. After 6 services the reminder isn't used anymore and you can't check through the menu how far you are from a service.
Note, this is not the oil change interval, that's another reminder inside the engine ECU.
21 - 23 of 23 Posts
