1 - 14 of 14 Posts
Just a heads up really, I've just picked my car up from the local Alfa dealer (Benfield, Newcastle).
They have an official notice in the service reception from Alfa recommending a cambelt replacement on all 147,156,159 & GT models at 36,000 miles or 3 years.
Apparently Alfa has had to cough up under warranty or give goodwill on an exceptional number of early cambelt failures.
I've just notched up 43,000 and I'm pretty sure they didn't change it on the 36,000 even though the service was around £400.
I'm not sure how long changing the cambelt at 36,000 has been policy.
I was quoted £350 for the job, a bit steep I thought.
M
It came in late last year, had mine replaced at 23,000 and it would of cost me nearly £400
W
There's a recent thread about the official notification but this has been "policy" on here for years now :lol:
£350 is a reasonable price if they're replacing the tensioners as well....DO NOT just change the belts. the tensioners are the main reason for failure imho.
wrinx
Wrinx, had all the work done re/cambelts tensioners on our 147 last August, with a more than decent payment from Alfa. Would you think it safe to assume the later tensioner/'s were fitted, and what is the major factor that is different?
Believe me, that's a fraction of what it'll cost if it fails. :(
I had my 156 serviced just before Christmas and Alfie at Heath Rod Garage told me to wait until next service and he would do them then ~£350 I think, my car will be ~39,000 miles then. I do have a rattle on start up at times but was told not to worry until next service!
W
I'd want to know what the rattle is and where it's coming from! Could be the top end draining oil a little or the variator which is ok, but if it's coming from the belt area get it sorted now.
I was lucky with my V6...was driving to the garage to get the belts changed (no noises), got within a couple of miles and an almighty noise started. an idler had given up with no warning at all...just made it!
wrinx
W
It is likely to be a metal tensioner, if you're getting it replaced within the next 3yrs or 36k I wouldn't worry anyway. Failures within these limits is VERY rare.
wrinx
Thanks Wrinx,my mind needs to be put at rest somewhat over this issue, otherwise I'll be stuck on Mogadon or something to get some sleep!!! Thanks mate.
has this come into play on the V6 engine as well, or is it just the tspark and the jts engines?
1 - 14 of 14 Posts
