sorry crazy weekend but got it all done
first set it to tdc and noticed the belt was out one tooth(f*& mackie did the water pump under warranty) note tdc is when the mark is at 9oclock and the button at 6 oclock, so stripped it all
replaced with new water pump, tensioner, idler and belt
lined up the belt there are lines on belt, to the marks on the pully,
tighten tensioner, in the pic it is only half way up the pointer needs to be over the hole at the top, once half way just lift the pointer with your finger and it should hover half way and then push it till it is aligned
did the nose with plastidip will post pics on that page
now with belt correct it should perform even better, had oil leaking in to the inter cooler because valves did not close fast enough :thumbup:
