Interesting that three of you have Porsches as well
3yrs seems shorter than for any other car - I think it's not the belt that's the issue (it has semi-rounded teeth and is thicker/stronger than older designs - has anyone seen one tear on a TS?) but the small plastic idler made in Germany that is likely to fail first (seize and melt). Or the plastic tensioner pulley if still fitted (teeth wear away, apparently).
Torn cambelts I have seen on FIAT engines were the older trapezoid-tooth type and over ten years old (in one case 18 years old).
In NZ it's the 24V V6 that has had all the cambelt problems and the TS has proved reliable. I know of several that are over 120,000km and ten years old without a belt change. But I suppose Alfa Romeo have halved the change interval in the UK for a reason (and I think it's those bearings).
Oh well, mine was changed this year in my Spider and last year in my 156, and I'll be expecting five years, but will replace if that idler bearing gets noisy. If I was buying an engine that had only done 10k since idler/tensioner replaced, I would expect the bearings to last several years longer - wouldn't you?
-Alex
