1 - 10 of 10 Posts
Just bought 01 Spider TS in Alfa Red/Pink. 66k engine is very smooth no smoke, noise or rattles, FSH but no indication whether cam belt was changed at 36K. How worried should I be? What % of cambelts fail before 72k ? Are we talking 2-3% or 20-30% ?
Best done at 36,000 so they all say now, although I did read that the belt gears of plastic were the main culprits for belt failure, and replacements should be metal versions. Anyone else read that in that magazine?:):
I would be getting it changed pretty sharpish if I were you, I wouldnt say its 100% failure rate but it would be well above 50%.
At least if you get it changed you know it has definately been done. My 147 2.0 has 64k FSH, and I know the belts were done at 36K and the balance belt snapped on it a few weeks ago (thankfully it wasnt the timing belt!)
No harm in inspecting the belts anyway and seeing what condition they are in.
I am going to echo the others and say get it changed now, along with the variator.
Getting it changed, is a lot cheaper than getting it fixed if the belt snaps, which could be up to £1500 if it needs a new engine.
There is not a lot of point checking the belt as it is usually the tensioners that give up and snap the belt in the process.
Thanks for all the input. I've booked the car in tomorrow for an early 72k service.
That's good. Don't forget the original recommendation was 72K miles or 5 years. It's now 36K miles or 3 years.
1 - 10 of 10 Posts
