1 - 18 of 18 Posts
done meself my first alfa cambelt today and for a newbie it took me 6 hours with help from the father ,
but what a t~#t to do aux belt serpentine and cam belt and variator
engine sounds a hell of a lot better now dead quite also done an oil change and filters and through a k/n induction kit on,
changed all gaskets inlet exhaust an so on
car was well over due needed it doin
i only got it 2 months ago but owner didnt no when the cambelt was last done ,
was stamped in book at 63.254 in 2005
oil and filter was done at 76000 in 2006 and the cars now on 99368
so hopefully nothing to worry about for a bit
except for m.o.t in a few weeks
just thought id let u all no
cheers
was boss when i first started her good old afla RAW
got quoted by my local garage 400-500 to do the job all in all well glad i done it bit of experience with my alfa ,
and saved a packet too
My GTV is due a belt in 15,000 miles. I am tempted to have a go at that myself.
I have done a few TS belts as well as belts on other cars, but I haven't done an Alfa V6 yet.
congrats m8 want to do mine? lol mine is due in 2k car shows 58k miles but its got a new engine as the old belt snapped and killed the engine, new engine has 33k on it so I know its due the 1st cam belt and the variator need doing as it sounds like a durv burner, need to start getting quotes for it as its well beyond my technical capabilities.
fair play mate! congrats on the job :)
imies reading 84k now but according to service history has been done twice! last at around 65k, how often do you think they wil need replacing?
cheers
Thats a year over time your a lucky man.
after reading some threads i thought id better get it done didnt fancy a rebuild,
didnt hardly use it after the first few probs i had (faulty cranck sensor)
so thought get it all done asap now shes back and better , so some styling after mot time i think
exactly what mike said ,but some ive read say they snap prematurely so sooner rather than later is the best idea , hope all goes well
mine sounded like a diesel bearing where fcukd in pulleys makes a hell of a difference
v6 sounds like a big job and tight in the engine bay ,carnt be that much different tho can it ?? if you do it keep me updated ,
I think it is a big job..
Still nothing ventured nothing gained... As long as I use the right tools I think it will be ok. :)
nothing ventured nothing lost either :eek:
done meself my first alfa cambelt today and for a newbie it took me 6 hours with help from the father.
What specialist tools did you use? I'm going to have a go at my variator soon. All the belts too. Other than camlocks, I aint sure if I'll bother with the rest.
I also used the TDC guage and the tensioner tool for the balance belt, the tensioner of the cambelt I was able to improvise as there is loads more space, the balance belt space is tight and the proper tool works a treat.
If you are doing the variator, the removal tool looks useful, also the camwheel tensioners would be good, I tried using my V6 tool and broke a bit off as it did not quite fit. Damn.
Using the correct tools saves loads of time having to think up solutions and bodges, TotallyAlfa do a range at most reasonable prices, no connection, just happy customer.
HTH
1 - 18 of 18 Posts
