1 - 20 of 57 Posts
Hey guys.Hope you well.Well baby's broken again and really would appriciate any help,over being ripped off by so called mechanics.Well my sele been broken for a couple of months now,Initially it was just the fact that when I tried to select gears it would just rock back and forward.Now I have engine fauilure,camshaft sensor fauilure.fml.Well I thought it might be the clutch rod length which is why I couldent select gears when the car was idling.So tried to set that and best I can do Is 24.9 mm then the bolt comes out.Even when I try and select gears after the clutch rod length drops do 16-18 mm anyways...
Please I really want to try and fix the car myself this time,But really just dont know where to start.
Ive uploaded some videos to youtube.Please take a peek and let me know what you think.
Regards. Sheldon
Okay so Dave,So you think that there is something wrong with the clutch arm?Had the whole box redone less than 10k kms ago :(.Were do you suggest I start?
yes the belt is only 30k kms on it..All the tentioners and pulleys replaced 10 k kms ago,new clutch kit also done at the same time :(.....
Discussion Starter #14
SO im assuming the clutch arm is the reason I cant set the clutch rod length and why the car just rocks when I try to engage gear?
engine sounded like that since belt change as i reckon its not been done right .........was it a specialist or local garage that did the work?
Discussion Starter #17
Were I live everyone claims to be a specialist ,But to be honest I dont think anyone knows whats going on,Thats South Africa for you..Ive tried 3 different so called Alfa mechanics around were I stay and each one has ripped me off.The last job I spent half of what the car is worth and it drove 10k and now its broken.:)
i suggest you go into your local lounge on this site .....there maybe someone to help advise or even fix your problems ..ill find link for you k:thumbs:
1 - 20 of 57 Posts
