1 - 20 of 24 Posts
Right here goes:rolleyes:
My 147 will be 3 years old in March so the cambelt issue is currently doing the rounds in my head. The thought of it failing fill me with horror!! Trouble is my 147 has only done 15000 miles and is very well cared for. (Its on its third oil and filter change!) Changed every 5000 miles. No variator noise at all when starting up etc. However, i might as well have a new variator put on for peace of mind.
As i live in Swansea the choice of who i trust to do this job are limited. First of all i rang Ashmoles the local dealer who quoted £550 just for the cambelt, when i asked about the variator the girl on the phone did'nt know what it was and could'nt tell me!! At that point i said thanks and put the phone down. Next i rang ***** & Yapps in Cardiff. The bloke i spoke to on the phone was very knowledgeable and knew all about Alfa Romeo cambelts but he was sceptical about changing a belt with only 15000 miles on it. He said he had never heard of a belt snapping with so few miles. He said that age does have a influence on the belt but only after about 5 years. He said mileage was more important!! He also said that alfa never said to change the belt at 36000 but it was a recommendation to change it??:confused: By the way they wanted £600 for a belt change(no variator).
After doing more esearch on the net i then discovered that twinspark engines from 05 onwards have different cambelt tensioners. If the tensioner is white its a newer stronger one. Apparently the old black coloured tensioners are engine wreckers. Often its not the belt that snaps but the tensioner fails and throws the cambelt off the shaft pulleys!!
Finally i found a couple of independant Alfa specialists who will change belt and variator for almost half the price of a main dealer.
NJS in Worcestershire will do the work for £285 plus Vat. Alfa workshop will do the work for £320 inclusive of Vat. I also found a firm called ********* based in Rugby who will visit you and do the work on your drive for £349 inclusive of Vat.
Anybody heard of the last firm and any experience of them? Having someone come to me and do work would save me a lot of travelling and waiting for half a day in a workshop!
I dont want to sound tight because i dont hesitate to spend money on the Alfa but being quoted over £600 for 4-5 hours work on a four cylinder engine sounds excessive(Rip off)!!
Would you change a belt with only 15000 miles on it?
Hi i just had mine done at 49,000 it was done 20 k before that (previous owner) but its been over 3 years so i decided that it was better to be safe than sorry and have to fork out for an engine rebuild £1200-£1500?
The belt was changed and variator etc and a full service for £450 at an Alfa specialists who seemed to really know their stuff.
Hope this hopes ya
My ex-boss did not get the cambelt done on her 147 at 3 years as it had not done 36K. The belt failed before the 48 month service when the car had done 34K - cost £1600+ to repair. Get it done now for peace of mind!!!!!
A
I can't see the point of giving main dealers the work at £500+..unless you contact ARUK and get their £200 (or whatever) contribution to the cost of the change.
I'd be reluctant to use the man who comes to you unless he is Alfa trained..how do you find him if he gets it wrong?
I'd take it to the specialist, even though it means a day off. In general the specialists are enthusiasts who try and do a decent job at a price you can afford. Many are Alfa trained, and they take a real interest in you and the car.
And yes, you ought to get it done. Bearings on cambelt rollers/tensioner will have deteriorated due to muck and salt over three years. Peace of mind is everything IMHO.
AlfaLincs
The choice is yours...replace the belts and the tensioners at 3 years or 36,000 miles, which ever comes first or play russian ruolette with the the 2000+ Quid repairing your engine if the belt fails.
As far as the variator goes, mine, in my 2002 TS has done 71,000 miles without changing and makes no noise.......
NB belts detriorate whether you use them or not and the life of the belt will also depend on engine running hours which does not relate very well to miles travelled. A car that does a lot of city driving and spends 'hours' going relatively going nowhere will have done more engine running hours than an engine that did the same distanc eon a freeway
One of the reasons belts need changing at 3 years regardless of mileage is that a low mileage car has often been used for short journeys and will have been started more often than a higher mileage one.
Starting the engine is when the cam belt is under the most strain, especially when the engine is cold, and these do have an effect on the belt.
The rubber in the belt will also degrade over time which is also a factor.
IMPORTANT NOTICE FROM ALFA ROMEO
As of 13/11/2006 the official service interval on cambelts on 1.6l, 1.8l, 2.0l Twin Spark engines and 2.0l JTS engines in all models has been reduced to 36,000 miles or 3 years (whichever is the soonest).
Try the recommended garages sticky thread for a decent Indy near you.
You won't have peace of mind until you get the belts changed!A mate of my brothers had a brand new 147 2.0litre and the belt failed at 24,000 and less than two years!!Luckily still under warranty,but would have cost him £1700.I agree the dealer quotes are a rip-off.I paid £230 to a good independant ( ex alfa dealer employee)at 30,000 miles.
Banned
Now I've been a naughty boy for 8 years, I took my 146TS in for it's first 3 free servicings (part of the package when I bought it) and since then it hasn't seen a garage apart from MOTs, thing is at 95K mine is still on the original belt and tensioner. I know the entire history of my car from new and when there's no noises to worry about then there is no need to change anything, It gets serviced every 8000 miles and I do my weeklys on it and if it hits 100K then that is when it gets a belt, tensioner and variator. Don't panic and rush into something you don't need, sometimes leaving well alone is better than replacing on spec. I had a belt go on a 2.0TS 155 and that was a scrapper but still that car had done 78K on the belt and what ****es me off is that it was on the way to get the thing replaced that it snapped. Ho hum, at least my next car was on the forecourt when I arrived with the 155 on the tow truck.
i can tell you're the kind of guy who has unprotected sex and then looks surprised when she misses a period.
its very irresponsible to suggest "sometimes leaving well alone is better than replacing on spec", just because you have been extrememly lucky it does not mean that will be the case for other people. the original belt has snapped at under 50k plenty of times, AR did not change the recommended service interval to 35k for a laugh, they did it because they were forced too by the number of premature failures.
But even if his belt fails, he's probably saved enough money not doing all those belt changes to just stick a reconned engine in it..
I'd not be so irresponsible with my belts, even on the slightly less prone to breaking V6 engine I'll be changing mine at 3 years, although I'm not so fussed about how many miles I do in that time.
My local garage has just rebuilt the head on a 22,000 mile 4 yr old 147. belt had not been changed. Just get it done, it isn't just the £1200 - £1500 repair if it all goes wrong, its the 2 weeks your car is off the road whilst it gets fixed.
My old v6 is having a new belt and tensioner. :)
The belt looks immaculate, despite having 60,000miles under it's pulleys.
I think you have to have a peek in there and try to judge it. If you have the new white tensioner and the belt looks good I'd run the beast a bit longer.
If it's the black tensioner and it all looks dry and dusty.. time for a change.
Ralf S.
its hard to believe why we own alfas, I'm doing my head at the minute big nasty job and no wonder 500+ is quoted. We should also tell the Italians to get this sorted, my sister could make a better system than this, I also have a 98 saab 900 turbo it has cahins and lots of very useful timing marks it took me 1/3 of the time to do it and was dead simple, we should start a petition to ask for chains and parts that are not made from old washing up bottles, great drive when it working though.
M
^^^ :lol: :lol:
You do wonder don't you? I mean they could just as well have made it simple as made it difficult and fiddly (on the 24V engine anyway - not tried to do a twinnie).
Banned
LOL, very good, but I am a supervising aircraft technician with many years of auto and aviation engineering behind me, the leave it alone theory is the way the aircraft industry is going at the moment and Ibet you'd be scared to know that airline companies have always believed in doing it this way as any time an aircraft is on the ground, it is not making them money. Where I work now, we would pull an aircraft off the line for a scheduled servicing which should last a week, invariably this would drag on to a month and while this was happening more would be queueing up, the servicings are now condition based as apposed to on spec, this has meant that the aircraft leave on time and has lowered costs down to 15% of the previouslevel. So with this experience behind me and the fact that I do examine the belt and tensioner every 5K as I perform my little servicings, I do it with the knowledge that when I need to change it, it will not be going to an overpriced, underskilled apprentice training center, but will be done by the person that knows the car best, me.
1 - 20 of 24 Posts
