1 - 11 of 11 Posts
Hi there I have a 147 2003 1.6 ts 60k and I what to change the cam belt as I don't know when it was last done. But don't know the cost or where to get it done. I live in Birmingham so if you can help then thanks.
I'd expect to pay £350-£400 and if the water pump hasn't been changed in the past, get that done too, it's about £40 for the part + fitting.
Make sure they will use the appropriate cam locks, there's 2 types according to the engine on the 1.6
Not from your area so someone will hopefully be able to suggest an independent near you.
Tried the search feature ... ???
Thanks gazza just had a look and I have found someone not that far away didn't even know that search was there
Shop around cos its only around 2 or 3 hours work and the parts are around the £100-120 mark excluding variator. Waterpumps with metal impellors are £18 from eurocarparts. I would feel miffed if i were charged £200+ labour.
Give Enzo at Autocasa a call. He is in coventry and is an Alfa specialist. Always done fantastic work on my 156 and his prices are very good. The number is 02477678535.
With TS/JTS pumps is more likely to be the bearing that fails, not the impellor. That's what's happened on the two I've had to replace: one at 128K and the other after only 42K.
The plastic impellor drops off a twinny waterpump hence why they are now metal.Ive seen 3 156s with this problem over the last couple of years.Logic suggests the first thing that is suspected is a closed thermostat but generally speaking they get stuck open.
1 - 11 of 11 Posts
