Hi All,
The air fans in my car (cabin air fans / air conditioning) have recently stopped working properly. The fans work, but only on the highest setting, 4, which is unbearable to have on all the time due to the noise. Does anyone know if this is an easy fix or more complicated.
No idea have never done one yet. But i'm sure its bolted to the motor so prob need to gain access to the motor to change the resistor
I no you may not want to but i would take it to a alfa dealer, as ive seen this fault many times before, on mitos and puntos and Fiat/Alfa have now modified the resistor and heater wiring loom.
Hope this helps
Just to update you's if any of you are interested. I have had a local mechanic had a look and apparently the switch to the rheostat had burnt out, and all he done was bridge it and it works fine now.
Hi All,
