Hi Symon,
Thank you for your response.
I'm located in Denmark, and i must admit that i have not checked the prices of a rebuild, because i thought this would be the most expensive option. I will give that a go.
In regards to the 1.6 Jtdm gearbox, it is higher geared. This worries me that the 159 will feel very sluggish, as it will take longer to come into the power-band of the engine.
The biggest problem i have with the gearbox is 3rd gear. Some gearshifts into 3rd, is almost like you have to go over a notch, before it goes into gear - making it a very long gearshift, and thus boost pressure falls, meaning killing fun. But sometimes gearshifts into 3rd are just fine.
Besides this 1st & 2nd are a bit clunky, but i don't know if this is just a "feature" of this gearbox. 4th, 5th & 6th are just fine.
I might also add that i have changed the oil to the recommended Fuchs oil from Autolusso. When the gearbox is warm (I.e after a long motorway drive) it the clunkyness & 3rd gear problem is less noticeable.
Best regards,
Thomas
