Hi all, apologies if this seems a stupid question but I've had a search through the forum and can't find anything about this in particular.
Anyone had a problem with an intermittent buzzing problem with their GTV or other models of Alfa? it seems to be related to the A/c and fans since when I turn them both off it doesn't happen.
Could be a relay getting hot...
Have a look in the passenger footwell under the glove compartment and you'll find the air con fan. Check it for debris. I had an annoying noise that sounded like the fan bearing had gone and it turned out to be a plasitic sweet packet stuck in the fan compartment.
To access the fan compartment undo the screw and then twist and drop out.
R
Agreed, that's what mine sounds like and I've not yet got round to pulling the fan out. My fan also seems weak as it doesn't clear the window in the middle very well although it's fine at the edges. I'm convinced there's a wrapper or a leaf or something stuck in it.
