Hi new to this site and am after some help. been looking on the net for a 159 usso jtdm estate. are the reliable. what goes wrong. are parts dear. what kind of mpg can you expect.any advice would be great. many thanks.
Do you mean the 1.9 dose not have a erg & dpf problem or are they not fitted.If you are going for a diesel, the most logical choice between performance and economy is the 1.9 JTDm (diesel) - this is based on the stock engine, nothing to do with EGR/DPF deletes or remapping. The 2.4 is obviously more powerful and a fantastic engine but in standard guise does not return mpg figures near the 1.9 (mid 30's vs. over 40). Tax and insurance is cheaper on the 1.9 also.
I've had 4 159s and I love them, the only major problems I have had were a EGR valve replacement on my first 2.4 JTDm and a clutch replacement on my '58 plate 1.9 JTDm Lusso Sportwagon. I have had the usual minor niggles, creaking clutch on all cars (except the current 2.0 JTDm), creaking windscreen (easy fix with silicone spray or at worst, refitting at dealers), rattles in B-pillar trim, whistling door mirror.
I'd follow sargents advice in his post above for older cars and then get searching - good luck :thumbs:
By the way there are a lot of similar threads in this lounge at the moment so do a search and it will throw up lots more information for you![]()
as cj said, they are fitted to all diesel 159's; 1.9, 2.0 or 2.4. I am talking about just looking at stock engines as you could get into the arguement of getting a 2.4 and then getting a remap/EGR/DPF delete which gives better economy (to standard 1.9engine levels) and power than a standard 2.4 and 1.9, or you could do the same to a standard 1.9 and then have the power of a standard 2.4 and also better economy than a standard 1.9................EGR and DPF set up and potential for failure is the same for the 1.9 and 2.4
