My rear door handle (external) on my beloved 147 has been pulled too hard and now won't open the door and i can't open from the inside as the child lock is on (h'mm brilliant) anyone got any ideas how to sort this out
can you get the door card off if so you could probably reach the child lock mechanism from inside
My car is in the workshop at the moment so I can't check, but can you access the rear of the exterior handle with the door shut? I can't remember, haven't spent much time in the back of my car!
I seem to recall a black plastic cover that you can remove to access it, but I could be imagining it!
Managed to undo the child lock through the gap between door and car body opened the door from inside, then the inside panel came off and reconnected the plastic device for opening the door, i think someone has tried to force it and stretched the internals will have to get new bit for it now. Cheers for the help
