Hi Everyone.
I run a '94 164 super with the 12v engine. The engine was recently replaced with something slightly earlier and bodged (expensively!) but was running ok for a little while. Now one or both cylinder head gaskets has gone due to an epic overheat due to a fouled radiator (I think - I've replaced that now) and I think I have maybe fixed the gasket leak with a liquid metal treatment (I'm sure it's really wishful thinking, but it does actually seem to have worked!! - will try to keep updates going on this!)
However: There has also been a fairly big oil leak into the valley of the V - about a litre every 200 miles - and the garage that replaced the engine thinks that it might be the head gasket leak. But in the meantime the oil seems to have flowed down the valley and into the clutch, which is now slipping badly.
I don't want to replace the clutch if the root of the problem lies elsewhere, so my question is: is there any oil feed / pipe running in the valley of the Busso V6 that could be the source of the oil?
Any help / suggestions / info very gratefully received!!
Steve
Steve
