Bit bored today so thought i would try the fabled ECU reset.
Net result is a ICS that wont switch on and a gearbox that beeps to tell me I am in reverse when infact I am in drive!
It was all fine before!!!!!!!!!!!!!!!!!
Im guessing I should do the ECU reset again to try and stop the buzzing???
As for ICS get busy with the trim and hope its a fuse!
reset the gearbox memory to learn my driving style ( car is a new aquisition) haynes manual at the top of the forum suggests it can sort out rough idles and other ailments.
Administrator
GT 2.0 JTS
You need to press the ICS turn knob on the right to bring up the 'enter code screen'.
If at first you dont suck seed..try Trill.
Try it again these Alfa electrons sometimes have a mind of their own.
just like computers when tyhey lock up..switych off and start again.
Pomeo
cheers guys, done it again and all seems fine however lost a wheel nut on the way home and very close to loosing thewhole wheel.
thats twice in under 1000 miles that the same 5 nuts have worked themselves loose, never had this happen to me before any ideas?
cheers
