Oh dear, I'm really having a bad car week! Today I've managed to sheer the kerbside halfshaft. I was dreading for a while that I had blown the diff or gearbox, so I guess in that respect I should count myself lucky. Pulled the wheel off and found that it had given up about where it goes into the hub. Didn't think I drove the car that hard...maybe just the culmination of 7 years metal fatigue. It has been making a faint rumbling sound on that corner of the car for a while...never been able to put my finger on it but assumed it was a wheel bearing, until now.
So, what do I need to replace? Looks like I need to attack it with a 36mm socket at one end and undo 4 hex bolts at the other? Is this the same stuff that is in the 2.5 V6, or is it specific to the GTA(s)? Is a second hand replacement going to be ok, or are these a common breakage that should be replaced with new parts?
Thanks in advance for any advice.
Edit: Had a hunt around and it seems broken driveshafts aren't new on the GTAs. Trailbraker gives good instructions on replacement in one thread. Quick question though...Do the outside CV joints come complete with the spline that goes into the hub? If so, that is what I need. Hopefully I can get a replacement without too much hassle here in NZ. I assume that CV is going to be different to those found in the 2.5?
