Hi guys,
Few days ago I bricked my device during firmware update in my AR159SW.
Finally i managed to find someone to do a flash dump from Brera and flash my device with that flash. So the result is that connect nav is alive but now I have another problem.
Device is searching now for MASTER CODE and nobody knows code from that Brera.
However I have a flash dump TE28F640, can maybe anyone find my master code from that flash dump? I will send it to you if someone can help? (i heard that master code is stored in flash)
I opened the bin file in wordpad and i see some 6 digit number is repeating couple of times at the end of the flash dump, but I am not sure if that is correct code.
Thank you!
Discussion Starter · #2 ·
Does anybody at least knows how many digits has master code for connect nav for alfa 159?
SOLVED!
One guy managed to read master code from flash dump, everything is working perfect.
