R
rjc_147
·Guest
Quick check,
When I unlock my Brera with key-fob the drivers window drops down a few cm, the passenger does not. Is it true that both should drop together?
It will drop if I open the passenger door manually. I'm thinking the recent cold weather may have done something as the passenger window is quite slow going down when I press the window switch.
