1 - 15 of 15 Posts
Can anyone tell me how to get the phonebook from my phone onto the in car display? the phone connects ok but i cant download (upload?) my contacts.
2006 Brera 3.2
Oli.
Sounds like you will have to transfer the data manualy from your phone-your phone must be like mine and will not do it automaticaly.
N
Standard Bluetooth is identical to Blue&Me.
If it doesn't give you the option when you pair
the phone, go into the car's phone menu (when
stationary) and there is an option under
"settings" to copy the phonebook.
the phone, go into the phone menu (when
Fair enough - but my B&M did it without prompting, whereas with standard kits I've had in the past it had to be set up (except Nokia to Nokia).
N
Some phones do, some phones don't.
(I've paired about 6 phones and 4 did, 2 didn't. ;) )
What phone are you trying to connect - phones with Symbian software such as the N95 will need to send each contact one by one can give you the instructions if you need them.
That would be useful for me. Changed mobiles to an N65 and it's not uploading like it did with my old non-symbian phone. Thanks
iangeneva,
Please find below the instructions of how to connect your N65 to the blue&me system
I am assuming you have got it paired to Blue and Me ok (if you havent then let me know).
press the phone button on the steering wheel
use the up/down button on rhs of steering wheel to get to "settings"
press the src button
use the up/down button on rhs of steering wheel to get to "user data"
use the up/down button on rhs of steering wheel to get to "add contacts"
you should get instruction coming thru the speakers now?
On your nokia go to "contacts" and select the first contact you want to send
select "options" then "send"
select "via bluetooth"
then select "selected detail only"
select "blue & me" from the list of devices
it should say "connecting" on the phone for a couple of seconds then the display on the car should indicate that received = 1
repeat until finished (press the phone button on steering wheel when done)
Hopefully thats it - if you've got a lot of contacts you might be there for some time
Hope that works for you - let me know how you get on.
__________________
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
1 - 15 of 15 Posts
