Hi all I have recently suffered engine management light on the car showing lambda sensor bank 2 sensor1 inactive.
Despite changing the part resetting fault codes checking wires etc the fault returns after running for 20 minutes
Might be a daft question but is bank 2 the right hand side sensor as you look from the front of the engine or the left one
I have checked it’s the right part and my electrician is at a loss
Only
Anybody with a solution please I would be very grateful
Malcolmlw
No real ideas here but perhaps disconnecting one, to force an error might let you figure out which is which? If the disconnected fault reported is on the same sensor as the one you have now, then that's the one. Otherwise it should be the other, if that makes sense?
Yes it does thanks and will try again tomorrow
