1 - 2 of 2 Posts
Hi Everyone,
Following another guide tightening up the guide rails for the drivers window I noticed 2 of the door lock screws / bolts were missing that hold the lock in place where it hits the striker plate. I replaced them with ones I had lying around. I noticed the lower one went in with the slightest of friction like there was some grit in the thread.
Now the door will not open from the inside or out.
I think I might have not reconnected the LED light for the alarm system but I can hear the solenoid in the door working fine.
I have tried:
Using the key
Opening from inside or out
Disconnecting the battery
Nothing. I worry I might have used slightly too long a screw and have now ruined the lock
I need to use the car tomorrow apart from clambering across can anyone assist on how I open the door without destroying the door card.
I read a threat how something similar happened on a 159 and access was gained through the rear door, not an option!
Any assistance or suggestions would really be appreciated.
Thanks in advance
Nick
Discussion Starter · #2 ·
Some progress
I have managed to remove part of the inner door card so I can access the lock. I can see the cable and lever. Pulling the door from the outside the lever moves upward as I would anticipate is normal but does nothing in terms of releasing the door. I have tried manually using my hand to push the lever up further but it seems to be at a stop; the full upward movement of its path so will not move any further but its doing nothing to release the door.
Help?
Nick
1 - 2 of 2 Posts
