1 - 20 of 28 Posts
I noticed recently during the hot weather that my dash has lifted on both sides of the car. I have heard it creaking sometimes when the air con comes on after the car has been shut up in the sun. Has any one had this or found a solution? It is almost impossible to press it down by hand so its going to take something strong to hold it down. Guess its a dash out job, its not bothering me too much at the moment but i think it could be job for those long winter nights.
One of those things that will annoy you every time you notice it.
Wonder if it is specifically a leather dash issue?
"One of those things that will annoy you every time you notice it."
Your right, yesterday I wasn't too bothered and now I am starting to check on it every time I get in the car to make sure it hasn't got any worse.
I thought it was just the leather and foam peeling off but it is impossible to push it down by hand. I don't know what the dash substrate is made from but it is as if this has warped in the heat. I can't say I relish the thought of removing the dash but I have seen threads on here by people who have removed it in about 3 hrs. What I do when I get it out is another question I can't see glue holding it in place, its just too rigid. Surely I can't have the only car with this problem I know East Anglia has been warm over the last few weeks but I'm sure Italy is hotter!
I would go and see a professional car upholsterers / trimmers as I think you have one chance to get a really good fix but if you end up doing it yourself and it doesn't work out it can be a nightmare.
its a leather issue, was a major issue on jaguar xf when they first came out
Sent from my 2014817 using Tapatalk
Agreed, after some research it appears that this is a problem with leather dashboards on a number of different manufacturers including Audi, Porsche, BMW, Jaguar and Jeep. Interestingly they all seem to go in the same place along the front demister vents.
Fortunately in Elearn the dash removal is well detailed, its a bit tedious but straightforward and with no obvious special tools. I have sent some pictures to Bespoke Leathering from Car SOS fame if to see if they can repair it and await there response.
Hi, I have had the exact same issue.
Tried to sort it myself but the problem returned within days.Also broke one of the demister vents in the process.
The foam under the leather has started to swell and its almost impossible to flatten. The leather seems to be cut very short with no extra to get hold of and pull down to fix.
I have also spoken to the leather trimmers as featured on SOS.
They have agreed to look at it but will need to take the windscreen out or the dash out to fix.
I had a quote from Alfa for a new Prodrive dash, supply only £4800 !!!!!!
Mine is put to bed for the moment whilst i decide what to do.
Let me know how you get on please.
Good luck
Pete
Sorry, I'm a bit late to the party as I know this thread is a little old, but I just purchased a Brera 3.2 S 2009 with the leather dash and noticed the same problem, where the leather doesn't seem to stretch far enough to the edge and no matter what I do it will not budge.
Did anyone find a solution or company that could fix it for a reasonable amount?
Alan
Alan
I still haven't got round to doing mine and it still annoys me every time is see it. Once it starts to go no amount of leather conditioner seems to stop it. Mine has now gone both sides and it is starting to go around the central vent. its a great shame because the dash is in great condition . The damage was already done went i bought my car, i think the previous owner must have parked it in the sun for long periods and never treated the leather. you won't be able to push it back, as the leather shrinks it pulls the plastic backing with it exposing the foam beneath it, it even broke one of the vents.
I have seen people who have had the windscreen out and had a trimmer try and repair it but i don't think you can do a proper job with the dash in the car and the ones i have seen all look repaired.
I am planning to remove my dash over the next couple of weeks as i recently had a mad moment and bought a new one! I still intend to take my old one to Bespoke Leathering to have it repaired but they won't discuss what can be done until they see it. I think the plastic backing will need fixing down somehow before the leather is repaired. I will try and post some pictures of the job so you can see whats involved. Hopefully when the old one is out it will be easier to see the damage.
Alfetta GTV6 supercharged racer, Alfa 159 3.2 awd Ti, Alfetta 2000 sedan
That's why in Aus we use dash mats! To prevent this and strong UV
Not much danger of too much UV in Suffolk though!...water damage yes...UV no....LOL. Just poor build quality.
I have the same problem. Would you mind if I asked how much the new dash cost? I’d like to replace mine - but fear the price will be prohibitively expensive for me :(
Discussion Starter #14
The cost of a new one from Alfa is totally ridiculous list price is over £5600 and I'm not even sure that includes vat. Even if the dealer gave you a good discount i bet you would be looking at over £4500
There is no way I was ever going to pay that much so I had resigned myself to spending a few hundred quid on a proffesional repair or replacing it with a standard dash. Recently one just happened to turn up on Partsworld and with my AROC discount I got it for £600. Still silly money and like i said i had a bit of a mad moment but I figured a repair could easily cost £300-£400 if its possible at all.
I will still investigate having my existing one repaired even if it's to keep as a spare or sell to recover some of the cost
I will certainly be taking greater car with the new one to keep it out of the sun. At least work now have an underground car park.
I have now had time to look at the procedure for removing the dash and it looks easy enough with no special tools required other than some trim removal tools and a bent screwdriver to release that airbag.
I’ve got a spare one too
Only way is to remove it and then re heat and stretch the leather down and then glue again
I have removed 3 dashboards now
But it’ll take you a whole weekend
A day to remove and a day to refit
The front seats, centre console needs removing
Could I please ask both mnmv12 and alfaromeo939s whether you purchased your new dash units using your VIN number?
I contacted Partsworld to order one for my Brera and was asked for my VIN. Apparently, the dash part number as advertised on the site (which was presumably the one sold to mnmv12 ) does not match my car. I was under the impression all 3.2v6 Breras have the red stitched dash and wasn’t aware there are differences.....or more than one version?
My car is an 58 plate. I would appreciate any ideas here.......thanks
Discussion Starter #18
My car is a 2008 2.2 model. When I checked my VIN with Partsworld it wasn't listed either but we concluded that it was probably because it was an option on this model and that it was highly unlikely there were more variants other than lh or rh drive. The new one looks visually identical to mine but I guess I will only know for sure when I fit it next weekend. It's going in whatever happens!
Thanks for that! Would you mind posting up how the fitting went .....that’s assuming you, the dash and the car are still in one piece ;)
I, too, cannot believe Alfa made more than one variation of the red-stitch dash - just left and right hand drive.
I shall eagerly await an update :)
I bought mine from autolusso s/h
Still haven’t fitted it
But I’ve removed and refitted standard dashes
Expect a £1,000 bill from any normal garage I’d say to remove and fit one
1 - 20 of 28 Posts
