Hi guys, recently i bought a "noname" 2 din multimedia player to replace the original nav system on my 2.4 brera. However, as you can see from the photos attached there is a compatibility issue. I would highly appreciate if you recommend me an adapter that i could buy so i can finally connect it. Links would help greatly. Thank you in advance.
http://www.ebay.co.uk/itm/UNIVERSAL-CAR-RADIO-STEREO-BARE-WIRE-TO-MALE-ISO-CONNECTOR-ADAPTOR-BLOCKS-PC3-08-/231161058555?hash=item35d245d4fb:g:4z4AAOxydlFTAg8E
then buy the connects2 fitting kit for the 159/brera
Very unusual for the unit to be supplied without the multi power in/out and speaker adaptor. You will still need the adaptor to make that compatible with Alfas non standard pin configuration. If your unit is new check whether the avert said that the din lead was included.
You may also find that the head unit is none standard size and you will have to modify the standard adaptor surround that most suppliers sell. You will probably need this kit and to modify the surround:-
https://www.amazon.co.uk/Connects2-CT23AR01A-Spider-Double-Fascia/dp/B00GY4CR3E
Or this that includes the adaptor lead that should ensure the steering wheel controls will still work.
http://www.ebay.co.uk/itm/Alfa-Romeo-159-Brera-Double-Din-Car-CD-Stereo-Fascia-Fitting-Kit-Stalk-Steering-/350559358638
You will also need one of these. The radio reception will work without it but it will be much better with it fitted:-
http://www.ebay.co.uk/itm/12v-Amplified-Aerial-Adaptor-Antenna-Booster-for-AM-FM-Signal-Boost-/251249747735?clk_rvr_id=1041498594655&rmvSB=true&clk_rvr_id=1094073807339&rmvSB=true
If you have not fitted an after market head unit to an Alfa before you are on a fairly steep learning curve.
Read this as a starting point and do a search on the forum for some of the other guides and photos.
http://www.alfaowner.com/Forum/alfa-159-brera-andamp-946-spider/931370-head-unit-stereo-upgrade-instructions.html
First of all ,thank you for taking the time to answer so thoroughly. I just have one question, since this unit came only with a naked cable, can't i create myself the female ending or whatever it is called and then connect it to the quadlock cable of the car?
Yes, but it probably won't work as well as you would like and you will still probably end up needing the adaptor.
The way the switch live works is a bit weird and relies on canbus input to trigger it. You can adapt the wiring to give the unit permanent live but I found that flattened the battery on my wife's 159 and that is the same as the Brera.
You will definitely (100%) need the adaptor if you want steering controls as these are canbus not just giving a voltage trigger as earlier cars like the 156 etc. does.
I see, then i will defenitely buy it. Thanks a lot for your input.
Also good luck squeezing all the wiring and adaptors behind the unit. They will fit but it isn't easy. I found that there is a small pocket of space down the LH side right at the back and most of the cables will just squeeze down there. It really isn't easy but can be done.
