Giulia Super Sprint, GTV V6
Before anyone tells me to search... coudn't find anything :rolleyes:
If someone can help me so I don't have to remove everything from the car as it's snowing outside :)
What is the correct bolt size for the 166 calipers? I know they are 13mm, but don't know about the thread...
Same goes for standard GTV calipers. They are 12mm, but the thread size is?
A friend is currently making some brackets for me. So he needs the sizes.
And one more thing. As I will be using 305mm discs, I need to offset the calipers for 2,5mm to line up the pads, right? This is the basic bracket design I will be using: http://forum.alfa145.com/index.php?act=Attach&type=post&id=9921
So, are the measurements correct for the 305 disc? I know that a few people used this design... so just wanted to be sure.
Many thanks!
I have checked ePer for the 166 calipers. It lists only one type of bolt. So it looks like the standard (non-Brembo) calipers have the same bolts as the Brembos... I'm pretty sure they are M13.
