1 - 9 of 9 Posts
hi have just replaced engine on 156 2.4 jtd also when getting engine out brake pipe burst on o/s/f were they rot since replacing i cant get brakes to bleed up no resistane at all on that side any ideas would be much appriciated thanks :mad:
1st person open & close nipple
2nd person press the brake pedal while person one open & close nipple
if not fluid comes out check the reservoir for fluid & check that the pipe ain't kinked or blocked.... perhaps the bleed nippe is blocke dor not bene opened enough
tried bleeding no luck bleed niple fully open do you have to have engine runing or anything different you have to do thanks
engine off.
if you leave the nipple open fluid should weep out
sound slike when the rubber pipe was damaged ??? .... perhaps the metal piping got damage too.
there is either dirt or a kink in the pipework *somewhere* or else ther eis no fluid in the reservoir.... which i assume you have already checked?
& you have repllaced that metal pipe?
how is the rubber pipe?
if you open the join of the metal/rubber pipe see if fluid will come out..... if not the metla pipe is blocked or else you have a master/abs system problem
is it raining where you are?
its lovely & sunny here in S.E. Ireland :)
i'm sure Smaky is near by you, he might be able to advise you too
1 - 9 of 9 Posts
