Yes all of them ally body with stainless steel cylinders / pistonsAre the GTV 305mm Brembo calipers made of aluminium? And those of the 330mm GT/GTA?
So why is nobody polishing them!? :irked:Yes all of them ally body with stainless steel cylinders / pistons
That does look great. :thumbup:So why is nobody polishing them!? :irked:
I want to do something different with the brakes on my GTV instead of the yellow/red/pink calipers. How awesome would this look?
They look the same, use the same pad, and both have radial mount points (with axial adapters) - I am thinking they might be the same (the adapters are definitely different as mount points differ on uprights)Are 330mm 159ti calipers the same as GT calipers?
They are not the same Ian. I had access to a very neat pair of red 159 calipers and they are slightly bigger (and more impressive looking) than the GT's but struggled to get adapters to work so kept looking for a pair from a GT. My 17" teledials were another problem which you may not have with 18's. TBH I think it is doable but will take some fine measurement to make up mock up brackets (and possibly some trial an error adjustment) before making final ones and it's very had finding engineering shops that will take this on for reasonable money hence me going GT OE - plug 'n play.You will be surprised what a good paint remover can do. Even "Brake Parts Cleaner" will strip the red paint off your calipers. I've seen it happen to a Golf R's red painted floating calipers up front. seriously, a performance vehicle with floating calipers...aranoid:
I'm planning a substantial brake upgrade but will provide specs once I have all the information that I require. It will entail new calipers and discs as well.
If you could find these adapters (which are from a GT) it may be worth exploring the 159 caliper option further. Strangely AR SA does not sell them separately from the GT calipers (but you can get them in the UK). When I last checked these GT calipers and adapters from AR were R6500 each!They are not the same Ian. I had access to a very neat pair of red 159 calipers and they are slightly bigger (and more impressive looking) than the GT's but struggled to get adapters to work so kept looking for a pair from a GT. My 17" teledials were another problem which you may not have with 18's. TBH I think it is doable but will take some fine measurement to make up mock up brackets (and possibly some trial an error adjustment) before making final ones and it's very had finding engineering shops that will take this on for reasonable money hence me going GT OE - plug 'n play.
...luckily I can pull some special strings in our workshop at work if I need to... :smoker:TBH I think it is doable but will take some fine measurement to make up mock up brackets (and possibly some trial an error adjustment) before making final ones and it's very had finding engineering shops that will take this on for reasonable money...
GT units bolt on to 305mm setup?... I'll get GT units because they are cheaper and bolt-on.
Arthur:GT units bolt on to 305mm setup?
no so sure...
That's exactly what I did ArthurB, fitted GT calipers to my 156 GTA, the photos are in the "red caliper paint" thread. The pics in this thread contain the adapter required and part number. The GT caliper bolts radially with 2 big hex bolts to the adapter and the adapter is mounted axial lay in the same way that the 156 GTA's calipers mount. It is a straight swop with that accepts the bigger GT/147GTA 330mm discs. I can report that it is a worthy upgrade (in fact last model 156 GTA's in the UK got fitted with these as they should have been in the first place. It is difficult to find GT Brembo's and adapters 2nd hand in this market though.GT units bolt on to 305mm setup?
no so sure...
Not the same uprights. GTV has McPherson strut and 156 has double wishbone. The brake caliper mount points relative to the hubs are the same, thus brake calipers are interchangeable.yes, but are the uprights the same on a 156 and GTV? That was the crux of my question.
Im fully familiar with fitting 330mm setup on the 156.
The uprights have nothing to do with the brake installation, but the caliper mounting holes are identically placed and they are therefore completely interchangeable.yes, but are the uprights the same on a 156 and GTV? That was the crux of my question.
