fitted all new pads and discs to my 2.0 155ts and the fronts squel really baddly with the pads it had some little plastic stoppers that push in holes in the bottem of the pads but they dont seem to do much also my oil pressure gauge jumps about madly once in a while any ideas
Discussion Starter · #2 ·
Oil pressure will probably be the sender.
Brakes, try filing a little chamfer on the edges...don't go mad though :eek: also plenty of copperslip on the pads (backs!!!). Are they seating properly in the caliper and carriers?
But, after all this it may be that they just need to bed in a bit ;)
wrinx
Oil pressure is either the sender or a loose/poor connector on the sender unit :D :D
And as for the brakes lots of copper grease on all contact points with the carrier and the caliper :D :D
