A few days ago I started to notice a slight grinding noise from the brakes. Specifically at slow speed - less road / ambient noise I presume.
I got the car checked out at an Alfa specialist - not used them before but recommended on here and close to where I was working. They said the noise was caused by the disks which had corroded on the inside and would need to be replaced at the same time as the pads. The pads had 3mm on them so this wasn't urgent.
That would be fine but the disks were only put on in May (10,000 miles ago)
I took the car back to the place that put the pads on and was told that this was a common problem - the noise that is - and even higher grade (Tarok) disks make a noise and it's nothing to worry about.
He also said that they'd "meet me half way" when I had the disks replaced.
Now, it didn't occur to me until later that this "meet me half way" offer actually means that the disks need replacing, doesn't it?
So, my questions
1) Is this normal? Do 330mm disks on a 156 GTA make a noise? A sort of grinding, rough metal sound, almost as if there's no pad left and there's something scraping that shouldn't
2) Should I get a third opinion? TBH I'm probably heading to Autolusson on Saturday anyway so may ask if the guys there can have a look.
Lastly the disks were sold to me as used, but noth that used in May last year by the garage who told me it's usual for brakes to make this noise.
So, my questions
