My guess is BMEP is around 11.5 bar. This goes to 13 bar for some direct injection engines and many boosted engines. Ring bypass then become a factor. BMEP does not relate to effective compression ratio, which have to do with cam duration. Meaning the valves are still open on the compression stroke and is not compressing. Then you can use a higher comp. ratio.
I believe the gauze is there to break water up and it does make a difference in performance. I measured 3.5whp more by removing it from a 2ltr. Don't remove the square blocks because the flowmeter will not measure correctly anymore.
My tuner do not like more than 80% working cycle on the injectors. On 1000cc injectors 70% is barely effective on 550cc 80% is max and on the Alfa's standard 190/220cc may be ok with 90% if the fuelpump and filters is VERY GOOD. The problem in this, lies in the recovery of the fuel pressure before the next injection. If the pressure do not get back to 3bar, the injector will p!ss out and not spray properly meaning you will have cr*p combustion and little power.
A 267deg cam is around the limit with std valves and seats on the Busso but on idle I lost the booster due to overlap. With 267deg(GTA2) I still had full lowdown torque but with 259deg(GTA1) and round seats and flat angled valves the overlap increased more and caused a torque drop low down. The valve job increased the flow, and power, close to the longer duration cam. This is not a problem as a 3.2 have more torque than needed on a front wheel drive at 2000/2500 rpm and didn't effect my towing a caravan as I stay above 3000 rpm.
