1 - 2 of 2 Posts
I've been told that the master cylinder on the 159 has a bleed nipple, but I can't see it, is this true & if so where is it please?
I believe all RHD versions have the same brake master cyclinder.
Look down from the AC piping where it meets the rear bonnet seal. You'll most likely have to remove engine cover for better visibility. You should see 2 bleed nipples with caps(or lost) facing toward suspension .
1 - 2 of 2 Posts
