Can I just top it up or does it need to be bled through? :confused:
yes you can just top it up.
Check the brake pads though as the drop in fluid level is probably due to the pads getting low.
Or a maybe leaking pipe?
Is it a sudden loss of fluid?
I'm not sure to be honest. I wouldn't have thought the pads are getting low though. They're DS2500s and were fitted 9000 miles ago.
Check to make sure there's no fluid on the top of the gearbox, could be the slave cylinder about to pop as the clutch uses the same reservoir.
