Im about to change discs and pads and Im intending to bleed fully the brake and clutch systems.
Im planning on using AP Racing Formula DOT5.1 fluid.
Anything against APRFF? Any better alternatives?
I have requested price and delivery on 1.5ltrs, I hope this would be a sufficient amount?
Discussion Starter · #2 ·
I guess nobody has any better suggestions on brake fluid then :rolleyes:
The required amount should be listed in the back of your manual under fluid specifications and capacitities?
Failing that a phone call to your dealer would sort you, you don't have to tell him that you are sourcing the stuff yourself when you ask the capacity.
I bought some standard brake fluid for a GTA recently but can't remember the amount except that I am pretty sure it was more than 1.5 litres.
Humour, 1 liter is enough in the 16 V if you have actually 5.1 but if not you have to replace all the system including ABS and so need 1.5 liter.
All 5.1 makes are good stuff. ;)
cheers
Jorge
