Hi guys
If I change the brake fluid at home on my 2014 Mito will that also change the fluid within the ABS module or do I need a dealership with computers to open/close valves within the ABS module to achieve a complete change?
Thanks for your help.
It will change it just by bleeding normally .. just don't get any air in the ABS system .. then you will need a diagnostic to bleed the air out.
Oh and the clutch is fed from the same reservoir so do that too ..
Your tag name XJI 1168, is that an Irish number plate that you've put on a Jag? I owned a lovely British racing green Jag XJ6 3.2 sport before I got my Mito nine years ago and it had the registration XJI 5501 :classic:
Hi Pookie.It's an Irish plate that came with my MX5. The Mito belongs to my wife - she always wanted a red Alfa Romeo.
