1 - 12 of 12 Posts
Quick question about brake calipers; what other models will pre-facelift 1.8TS brake calipers fit? I'm selling a set. Cheers
Front or rear?
Fronts, should be vented discs so should be the same for most nonGTA 156s except early non-vented 1.6s.
Rear, pretty much most 156s.....
Very little demand for fronts however...can't remember last time I sold any.
Until about 2001, the 1.6TS, 1.8TS & 1.9JTD had the smaller solid front discs.
For 147, only the 105hp 1.6TS had the solid fronts.
Thanks ppl.
Both front and rear from pre facelift 1.8.
Thanks ppl.
The front & rear brakes of the 1.8 changed a year BEFORE the 2002 interior facelift, 2-years before the full facelift.
So pre facelift 1.8TS can have 251 or 276 rear discs (both with early & late pads, so four versions each side!) and solid or vented fronts.
2001 was the change year.
So saying "pre facelift" doesn't really narrow it down!
Ah I see. It's pre 2001. 1999 in fact. I thought they updated the brakes along with facelift, like any logical manufacturer might!:xmas:
A 1999 156 will have the smaller solid front discs and the small 251 rear discs.
I know, just had mine replaced with larger rear discs and vented front discs. Hence the spare calipers I have to sell.
My question is which other models will they fit? 1.6, 1.8, 2.0, 147?
Discussion Starter #12 (Edited)
Ah I'm being thick. Literally just bought myself a 3.2 GT so mind is elsewhere!
Edit- I assume the same models for the rear?
1 - 12 of 12 Posts
