1 - 2 of 2 Posts
M
Hi all.
I need to change front pads, a relatively straight forward job however I would like to remove the brake callipers for a good clean up which means disconnecting brake lines. Its been a while since I have bled brakes certainly never on a GTA so is there anything I need to know or is it just a case of pumping the brake pedal until the air is removed?
Thanks.
It's like with all other cars heaving this type of brakes. Pumping the pedal, holding the pedal, opening the screw, closing the crew, releasing the pedal...:). Or get a bleeding tool and you can do it alone.
1 - 2 of 2 Posts
