OK some of you might know I was having low oil pressure problems with the Spider, thought it was the oil pump after a check up at a main dealer. After my Indy garage took the sump off it turns out there pretty bullet proof and it ended up being worn main bearing shells and scored crank end. Horror
previous owner ran it low on oil and the damaged was done
So, engine out and the blocks being freshened up with satin black paint (hammerite) the cranks being reground, pistons, con rods and fly wheel lightened and balanced, balance shaft removed.
I have a rebuilt head ready to be fitted.
New clutch will be fitted at the same time.
Is there any good advice or info any1 would like to give me?
Cheers Andy
Cheers Andy
