hi all
loads of water in my boot. it comes in where the fixings are for the hinge on the right hand side of the boot. so hinge has been off re sealed - still leaks. so did the water test opened boot and poured water over the hinge -no leak .then poured water from top right of windowscreen. the water started to come in under the hinge fixings. so on monday i had the windowscreen took out and re-sealed incase it was getting under the seal - guess what still leaks. this isn't a small leak either i've got all the linings out the boot and have to have a sponge in the boot! - baffled - help !
hi all
Just spotted this post, exactly the same as mine! did yiu cure it in the end?
Rob P.
