My series 1 1750 has a boosted 2 litre Alfetta (Alpine Turbo) with 8.1:1 CR and running 0.8bar boost. Before I get crucified for messing with a series 1 1750, just know that I bought it this way almost 3 years ago and it has been a project ever since….My most recent problem is that it popped its head gasket (between No 2 and 3 cylinder). The car never overheated – it just started misfiring and I did the usual (spark and fuel) checks and determined the head was pad-op. Also, before I took the head off I started it from cold and it purred like a cat for about five minutes and then started missing again - each time either No 2 or No 3 cylinder was the culprit.
Decided to take the head off carefully in order to try to identify where the problem lay -
Firstly, I did notice that the head bolts did not appear to have the same torque when I removed it - the way I checked was to set my torque wrench to at 80, then 70 then 60 Nm and each time turn the head bolt tighter to hear 'the click'. Engine was cold – doing this 'test' some head bolts did not click at 60 Nm (WTF!). So first assumption is that original torqueing was suspect (it been running like this for a while). I never assembled my motor but I will be refitting the head myself for sure!
Looking at the head gasket (Victor Reinz) there are no kinks or obvious signs of detonation. I am attaching photos (hope they download properly). So gasket fine but head definitely lifted – so either head not torqued properly (therefore uneven pressure on gasket) or V Reinz never designed gasket for high cylinder pressures. I would have expected that if I had a detonation event or a pressure event and the gasket blew that the gasket would show some signs of this.
My liners are cooper ringed and there were no signs that it blew on the cooper ring side – if you look carefully you can see the cooper ring indentations in the (liner side) gasket fire rings – so, toit on the liner side – does that mean I need to do a receiver groove on the head as well. I am deliberately not running serious boost (for all the known reasons) so this would be overkill surely.
So, last test as to the gasket fault is to have the head checked for trueness and pressure tested. Using a flat metal engineering rule it did look like the head was not so flat anymore (by a ball hair) but the engineers will confirm trueness and pressure check outcomes.
So my first question is
• Assuming all is in order with the head – still true and no cracks, do I just refit the head (torqued properly this time) with another VReinz gasket, or
• Do I go for a different gasket –
o MLS - I cannot find an MLS gasket for the Nord (Nava Linea Sport makes a gasket with separate INOX stainless steel fire rings that according to the US Alfisti is the 'final answer' to all boosted Nord head problems. Problem is I do not speak Italian, they do not answer their emails – so they are permanently on lunch – the P-I-G-S economics acronym seems to be appropriate here
o Copper – an interesting proposition – has been used for years by the hard-core drag racers, and has all the right properties but its known problems are not sealing oil and water jacket well – so you'll have fantastic cylinder sealing but you block/head join will ****** and mix fluids like an incontinent. Which is why MLS headgaskets become such a rage. An additional problem with the Nord's is that the liners protrude ever so slightly above the deck. To my mind this makes the likelihood of a fluid leak/mix problem worse. There is a local manufacturer, Redline Headgaskets that actually produces and impressive looking copper Nord Alfa head gasket - Alfa 2L - Redline Gaskets. Do the engineers in the house think a solid copper gasket (with proper raised sections around oil, water and liners – like the redline gasket) is a problem for other reasons? Has anybody ever tried this and found it to work?
Please help
Please help
