I can't get under the bonnet of my mk1 sportwagen... when I pull the bonnet release it clcik and the bonnet pops a little but not enough to release it fully....
any ideas how I can in??
cheers
Your secondary catch has seized from lack of maintenance.
Search on here for bonnet catch.
You will find it comes up a lot!!
DON'T DRIVE IT UNTIL SORTED.
thro the grill spray in a lot of WD40 onto the safety lever.
if that fails oyu can open 3 10mm nut, visible thro the grill, 2 at the top & 1 at the bottom, they make the shape of a V.
once these are open you came pull the frame forwards & then you have abit more acccess to the mechanics... the bonnet will lift appox 5" before the cable stops it form rising more
i know this coz I spent 30 min;s last night doing the EXACT same thing as oyu'll need to do.
also try a 2-person approach. fully close the bonnet (so it locks). then have one person firmly push DOWN on the front edge; this will take a bit of pressure off the lock catching spring mech; other person then pull the lever. with the lever pulled, the person holding the bonnet should let go, and see if it springs up properly. if not, try jiggling the bonnet with the lever pulled.
