·Very sorry to ask such a stupid question.
1997 (first registered in 1998) Spider 916 ph 1
I have the "bonnet open" warning light illuminated. Try as I might I cannot find the switch to check/adjust it. The bonnet is actually firmly closed and if i reopen and slam down the light goes out, only to re-illuminate as soon as i start driving.
My workshop manual (a CD bought off e bay) appears to show location for a phase 2 and for RH Drive variants, and my switch is in neither location.
As indicated above although my car is first registered 1998 it may be a 1997 car. I say this because I understand some changes took place to the ph1 cars about this time and I am not sure if this is the case here.
The workshop manual indicates that it is located adjacent to the near side bonnet hinge, but if it is I cannot see it. Neither can I see it on the off side by the bonnet hinge or on the front cross bar under the two latches (which was my first thoughts on where it would be).
I must admit that it was hissing down (persistantly raining) and my gas struts do not work in cold weather so I was battling both the wet running down my neck and i was one handed because i was stopping the bonnet from falling on my head, not the most ideal conditions for doing a search, but I did spend quite a while looking.
Manual indicates a plunger sticks up out of the bulkhead area which is depressed by the bonnet. I just do not appear to have one. Am I blind or stupid?
