1 - 2 of 2 Posts
Hi
I have got a 2001 156 .... the bonnet seems to have moved on one of the mountings? one side sits on the wing the other has a 10mm gap .... I assume it has moved on the mountings ... do you know where the mountings are located ...assume they are under the trim that the wipers pass through at the bottom of the windscreen ? Can anypone confirm?
Paul:(
W
It'll be the base of the hinges...welcome :D
Edit: just had a look, I think the adjustment is the single bolt attached to the bonnet side of the hinge.
Can't really see what's at the bottom side, even after removing the spongy bit.
wrinx
1 - 2 of 2 Posts
