1 - 13 of 13 Posts
0
Did this a while back - just thought I would share :)
My bargain BMC CDA arrived today
Car up on axle stand
Intake removed & battery tray out - 13mm & 10mm sockets & 10mm spanner
'snorkel' prised off the airbox & bolt removed with 8mm socket from underside
Bracket removed from rear of airbox with 10mm socket to ease removal
I undid electrical connectors to give more room
Airbox half way out
Result - it's out! - bit of jiggery pokery involved getting it through coolant pipes etc
Old & new
Bolts in existing airbox sheared (of course! [:p] ) while removing MAF housing (10mm socket)
I 'kinked' the fixing strap through 90º to enable fixing of CDA
I fixed the strap using the same bolts that fix the fan to the rad (8mm socket)
CDA then fixed to this using 10mm sockets
Battery tray & intake re-fitted
Have beer while doing write-up [:D]
Not fitted duct to bottom of CDA yet [:$] , but will do so before driving in the p*ssing rain [:D]
fantastic I had a nightmare fitting mine.........
This should be made a sticky for everyones future reference...
Well done
0
Induction noise is great! Performance wise slightly better, but assume it will imrove when ducting is fitted
At the mo I suspect my set-up is creating suction within the CDA
0
Normally £171, but I found mine on ebay (brand new) for £100 :)
Ok not sure I'd wanna go through the prosses of fitting that, as my technical abbiliaty is bad(really really bad).
Where could i pick one of these up and also have it fitted at the same time??
0
I would have thought any decent 'tune-up' place could supply / fit one, but there's not that much to it really if you can turn a spanner :)
Thread ressurection time :)
Where did you buy the red silicone pipe (I assume it's a reducer?)? I have a BMC CDA and an Autodelte carbon pipe (on it way) and may need a few of these.
0
No worries - if you know what size hose you need I'll measure the one I have & stick it in the post if it's any use
I'm hoping to attach the CDA to the autodelta pipe and move the maf up near the throttle body so I'll need to pull everything apart and mesure it all up.
1 - 13 of 13 Posts
