Hi All,
Hoping I can get some assistance with a dead Blue and ME in my 2012 Guilietta 2.0 JTDM i.e no bluetooth, steering wheel buttons, and USB not working.
First symptom was the flashing odometer. Then discovered Bluetooth not working.
So far I've tried 2 second hand BM modules (PN 50525925) multiple proxy alignments,battery disconnects etc etc.
Proxy alignment keeps failing and won't see the BM module with a timeout error message.
The curly one is that during the proxy alignment the air bag node also comes up with an error 'Out of range' but when you check the airbag node for faults there is none and on the CAN set up page the airbag also shows OK (Airbag Node (NAB) EOL OK).
Tried 2 different scanners, multiecuscanner with laptop and a snapon modis scanner.
I'm starting to think that surely I haven't got 3 (albeit second hand) failed modules and it might be something else.
I've now dropped it off at the dealer (Zagame) to see if their equipment can better diagnose the issue but I have a feeling I'm not going to get the response I'm after..
Any help would be greatly appreciated.
Cheers.
Cheers.
