1 - 20 of 25 Posts
Had a blowout on the M3 tonight, on the rear. Shame as the tyre was in great condition. Do I have any kinda come back on the manufacturer? The way its split all the way round on the inside wall gives me the impression its a manufacturing fault, but it could just be the way blow outs happen.
Unfortunately, I have a feeling this might force my hand, and lead me to park the GTA up for the next 6 months or so. It needed lower arms and a few other bits, and now another tyre. For the cost of a tyre I can tax the old rover I used last winter, and will give me 6 months cheap motoring. I'm yet to decide...
M
You'd struggle to get the manufacturer to accept blame.
What 'was' the brand??
M
It's a PS3, was in great condition with tons of tread left.
A damn good tyre............but the manufacturer will blame the fitter at best :(
I know what you'll say............but are you sure that the wall wasn't hit against anything between the fitting and the incident??
M
1 million percent. It went on the inside, and my alloys are unmarked
I still think you'll get no refund mate :(
Slightly OT, but are you going to do the arms and other work you mentioned yourself??.it's worth it to save the labour.
33 is the 147 GTA spec.....what is it on the 156??
2.5 Bar Front (just over 36PSI)
2.3 Bar Rear (about 33.5PSI)
A lot simpler if you use Bar rather than PSI...
That is for reduced loads.
For full loads it is 2.8 Bar Front & 2.6 Bar Rear.
M
Running at 32 psi really 'shouldn't' cause an issue then.
M
It is still under pressure, which is never a good idea...
A fair point, and I'm also a stickler for running tyres to the maufacturers recommendations, but a pound or two under wouldn't warrant a blow out.
Discussion Starter #17
New PS3 ordered from Camskill for £107. Local shop is gonna fit it for a fiver.
That makes £112 all in. Much better than the £150 quote I got earlier in the day.
1 - 20 of 25 Posts
