1 - 11 of 11 Posts
B
Well I dont know, I've been having a slight problem with my maserati stuttering & generally messing about & the other day it was just bogging down all the time , so I sent the ECU over to that place in Filton near Mod & Europarts they have a machine that can read the Ecu or Ecu's on the .
Anyway not good news at all, one is beyond repair & the other ,well they are teeth sucking about that one too so I'm worried now.
Its seems that water has been getting into the Ecu's from the bulkhead because a Grommet has perished over the years & its buggered them.
So I am a bit fed up, I was thinking of selling the M3 but I may now have this sorted & sell them both & get an old E55 barge to float around in.
Sad that is mate!:(: Still at least motors ageing can sometimes be sorted when the bits are found. Not like the old human bod, which finally becomes unrepairable?:(:
M
Ring Meridian Maserati as they know a lad David Eskew and he breaks them and is very reasonable, hope this helps
B
Thankyou ,yes I know David I have bought many parts for my old 430 track Masser from him.
Its just so Typical I have not skimped on this car ,I have bills over the past 5 years of around £9700.
The garage I use are great , no its just one of those things, a grommet/rubber plug on the Bulkhead which is hidden from both sides ,you would never see it unless you were up under the passenger footwell & the trim off or again the trim off & the wiper motor moved to see it in the engine bay ??? It looks as though it may be brittle due to heat from the engine bay what ever its a pain.
It wont be cheap thats the only thing i know!
One of my son's freinds has suggested using some sort of "PiggyBack "aftermarket ECU ?? not to sure about this idea he says its a really good thing as it will be cheaper than a maserati ECU (No argument there) & there is far more scope to tune it properly .
Well I may look into this ,anyone here heard of these ?
Thanks lads for your input :thumbs:
D
You can't use a piggyback:( Unfortunetly as they run off your standard ECU which is dead as you say:( So it will have to be full standalone system like a Motec or a Omex, Gem's or VEMS unit. All pricey but worth it as they can fine tune your engine. Motec being the best really but certainly not the cheapest.
Porsche Cayenne Diseasel (2011)
Sorry to hear this - Ghibli's belong on the road, not waiting for resuscitation in a shed somewhere...
Hope you can get it fixed for an acceptable budget.
1 - 11 of 11 Posts
