How do I bleed the bleeding radiator?
I've just done a timing belt, water pump etc change and full service on my 159 1.9.
I drained the coolant using the little tap on the bottom drivers side of the radiator, so refreshing not to have to pull hoses off. The only problem was I had the drivers side wheel off and the car jacked up so quite alot of old coolant stayed in.
I refilled using the expansion tank and bled it through the little bolt on the metal pipe at the front of the engine. I then spent quite alot of time with the engine running squeezing the main rad hose that runs across the front of the engine bay, trying to burp the system. Even when the car was up to temp on the dash gauge, that top hose wasn't hot. Also it didn't feel full of water.
Is there another bleeding bleeder I've missed?
thanks for any help
Jonnym
thanks for any help
Jonnym
