For future reference (next weekend's reference, to be precise!), how is the clutch bled on a 156?
Does it share its fluid with the braking system? I don't remember seeing a separate reservoir for it anywhere... :confused:
Cheers,
Iain
share the same resevoir as brakes so if you are doing the clutch you might as well do the brakes too.
the bleed nipple is under the L shaped rubber thro which the flexi hose passes.
remove the rubber, & you'll see the nipple.
the pipe need to come back apporx 7mm to allow this to bleed.
to allow that to ha[[en you have to lift UP the 'horseshoe' clip that keeps it locke din place.
or
look at Gazza82 website for a guirs, the pictures used there are MINE :)
^^^^ me too ^^^^
was goin to ask you for same ;)
